ISO Beginner Rig - Daggerboard
Windsurfing or related items for sale, free to a good home, wanted etc.
darkingkob
rookie
rookie
Post by darkingkob »
Looking for a beginner rig - pretty set on finding a center daggerboard fin style board to avoid water starts.
Need board (150L?), sail (5m freeride or slalom)/boom/mast/maststep
Thanks!
superstar
superstar
Re: ISO Beginner Rig - Daggerboard
You don't need a dagger board to uphaul. It just helps stay up wind.
darkingkob
rookie
rookie
grantmac wrote: Sat Aug 14, 2021 8:32 am You don't need a dagger board to uphaul. It just helps stay up wind.
For sure! I just don't want to uphaul from in the water. With a floating board if I have to drop the sail for some reason, I don't necessarily have to get soaked to get started again
superstar
superstar
darkingkob wrote: Sun Aug 22, 2021 10:09 pm @
A dagger board does not effect this, board volume does.
darkingkob
rookie
rookie
grantmac wrote: Mon Aug 23, 2021 3:02 pm
True, I just don't see any daggerboards that sink so it felt like killing two birds with one stone in the description
local legend
local legend
150 is not a big board for uphauling and beginner learning and daggerboards are generally found on larger ones so you must be a lighter person. That’s good because slalom and freeride sails you are looking for are mostly fairly fragile monofilm so falling into them would damage them easily. Wavesails can take more abuse. As to not getting soaked unless you are drifting around a pond you WILL fall in .....that’s why it’s a WATERsport lol 😂
I have a used beginner boom, extension and bases as well as 5.0 wavesails if you are not looking for new.
Good luck
superstar
superstar
There are lots of old boards with dagger boards which will be so narrow you can barely uphaul them. Modern boards which generally don't have daggers are wider and easier to uphaul.
A better question would be where are you sailing, have you done any windsurfing before and what is your weight.
superstar
superstar
