Wing Travel Board Bag $140
Wing Foil travel bag fits 5’3 or smaller board and lots of gear. Never used. Description from manufacturer:
Travel easily with maximum protection and convenience.
The Wingfoil Travel Bag Wheel GONG ensures your quiver is perfectly protected while also making transportation easy with its sturdy wheels.
Perfect for long-distance travel, it offers protection, effortless organization, and ease of transport.
With its generous capacity and 25 cm sidewall, it can fit a board, three wings, a mast, a lower laid flat on the board, as well as essential accessories like a helmet and a pump, all while keeping your gear in perfect condition.
Uncompromising protection and durability
The Travel Bag Wheel is designed with premium materials and reinforcements to ensure optimal protection for your equipment:
• Differentiated padding:
- 25 mm foam sidewall designed to shield the rails of the board, the most vulnerable part to impacts.
- 15 mm of foam on the bottom to absorb shocks to the hull during loading and handling.
- 5 mm of foam on the top, sufficient thanks to the wings that add extra protection.
• Thermo-insulating and water-repellent inner lining: Reflects heat and reduces moisture to protect your gear.
