WTB: 3.7m Sailworks Revo
- renegade
- rookie
Re: WTB: 3.7m Sailworks Revo
Hey thanks for that offer! I got a similar offer from BigD for a 3.7m Naish as well.
Really trying to snag a 3.7m Sailworks...I did a project long-time ago with Bruce P and try to sail on Sailworks sails.
K
K
- tweezer
- amateur
- Has thanked: 4 times
- Been thanked: 17 times
Rene,
I have a 3.5 Revo... 2003. Hardly used it until windfoiling in RB. I think you might want a newer model.
Cheers,
Tweeze
Cheers,
Tweeze
- local legend
- Been thanked: 3 times
have you asked Bruce P directly to see if he has a Flyer demo or prototype? Foiling sails you really want a combo of low end grunt to get going and then depower, and I think most of the wave sailing or Gorge small hi wind sails are tuned for much higher winds than you'd use them for foiling.
- superstar
- Has thanked: 12 times
Interesting. I had a 4.2 Revo which was my 'go to' sail in high winds.
I will be getting a similar 3.7m or smaller sail for anything 25kts + as the cam'd sails don't depower enough in high winds. who thought I'd ever be using a 3m sail..??
just my 2 centablos.
yours truely,
'small sail bobson'
yours truely,
'small sail bobson'
- local legend
Are the flyers cammed Bobson? That would change my thinking for high wind for sure
- grantmac
- superstar
Flyers are twin cam. Personally I'd want a 3 or 4 batten sail for high wind then plan to rig super small.
- renegade
- rookie
Hi all,
Got a 3.7m Revo sail direct from Sailworks.
I'm sticking with "camless" wave sails for ws foiling as I'm not into back/forth foiling.....got a new 2022 Airbolt Carbon board and MFC Helios foil coming (thx Jesse!)...the Airbolt's position of footstraps, mastrack and fin boxes all close together means it it feels more like riding a waveboard.
Keith Teboul: “The Airbolt marks a new direction in wind foiling, bringing the feeling of rail-to-rail riding and high wind bump & jump to those ‘average’ days where the conditions at your local spot are marginal. Designed around the MFC Helios foil range and no-cam freeride, freestyle, and wave sails. With the rider back foot positioned directly on the foil, and with mast box placed further back than other foil boards in the market, the Airbolt delivers the industry’s most direct feeling from the sail to the foil. The Airbolt brings it all together, from early and easy take-off with maximum acceleration to rail-to-rail carving, gliding, and pumping, requiring minimum sail/wing or paddle pressure. We learned that foiling is extremely easy and more fun, when the playing field is balanced. You can start flying on the Airbolt on as little as 8 knots, having the same up-wind angle as if you were on a giant formula board but faster, and with way less effort and a much smaller sail, and going down-wind, you can surf the chop, with the same sensation as if you were on a wave. The mistake I usually see people making at first is over-sizing their rig. The bigger your foil is, the smaller sail you will be needing. For example, if you are using a 1400 front wing, you can easily put 2 square meters smaller sail than sailing on the fin.
Check it out here...
https://goyawindsurfing.com/boards/y202 ... lt-carbon/
https://youtu.be/Of5jO3lMbAU
Here's the 2019 used 3.7m Revo:
- 3.7 m Revo
- thumbnail_IMG_6300.jpg (50.01 KiB) Viewed 441 times
- superstar
Looks pretty Saweeet KC-Renegade!
Not many 'Bright Red' sails out there anymore, you'll be easy to spot.
I'm going with the bright colours as well.
Looking foward to hopefully seeing you in June.
