KS3 4.9, 400 cm 90% Mast, Fanatic TriWave 88l
Posted: Tue Jul 23, 2024 9:30 am
Asking 1100$
I’ve decided to pull the trigger and sell all the rest of my windsurfing gear, including a quiver bag and a Huge triple board bag.
The Quiver is a fanatic TriWave 88L (It has mileage dings, and the nose has been repaired, but this was my go-to board for all my sessions for a couple of years. One thruster is epoxy glue in the fin box until it gets repaired, but unless you are not playing with fins and need to take them out, it doesn't change anything!
I do have a KS3 4.9 prototype, (the mast sleeve is made with a lighter material. I'm missing 2 batten screws, but I was using the one from my other sails (it takes 1 minute to sort it out unless you get out the lower batten one!!)
KS3 400 cm mast (same as the one you've bought already)
A Naish alu bood (135-195cm) With Dakine 30 inches harness lines
Chinook 30 cm alu mast extension
Naish Starbase with a brand new tendon (Both Euro set up)
Quiver bag is a Dakine (I used to put both masts, boom and the 3 sails in it)
I also have a medium Dakine waist harness.
