Alternative to Cook St.
Posted: Fri Jan 30, 2004 3:57 pm
Hi. Just got back from a wicked session on the ocean across from the Esquimalt Lagoon. I was on a flattened 4.8 from 9 til noon. I've been sailing this place for years and hardly ever see anyone else out. It's a great alternative when Cook St is totally nukin'. The wind is generally about 10 knots less than what you get at Cook St. The water is choppy with medium sized swells on the outside, and flat on the inside - good for jibing . There is lots of parking, grassy areas for rigging, flat sandy beach, clean water (no logs or reefs) and no stairs.
The only negative is that the Westerlies can be a bit gusty, sometimes more than others. Check the lighthouse reports to see how it is. On lighter days, the wind tends to be cleaner a few hundred metres out so you either have to slog or wait for a gust....or go to Cook St! It's really good out near the barrels (middle of the beach). I don't recommend sailing in the lagoon itself as it's a total gustfest. It is a safe place to learn though.
The best wind is a SW. It's side shore and very consistent. NE is also very good at this beach. Also side shore and consistent but f--king cold
About once or twice each winter, when a honkin' SE pushes through, the lagoon is a really fun place to sail. It has to be really cranking everywhere else though (35-40 at Willows). The wind blows offshore (onshore on the ocean side but killer waves and HUGE logs) and the water is dead flat. You can do speed runs up and down the length of the lagoon about 20' from the beach. It's fun to watch the drivers in the cars as you speed past them!
Anyways, just thought I'd let everyone know that this place can be a great place to sail especially when it's too big everywhere else. Either me or my gear gets thrashed on those days so I tend to avoid them. I'm not sure how accurate the lighthouse reports are. The reports for Vic HArbour sometimes seem a bit closer. I've had some great sessions on an 88 litre board in what was apparently about 14 knots. If BWD is over 16, it's usually sailable especially if it's SW or NE. Best to pack your 6.0+ though, just in case.
Cheers
Cheers
