Tying your lines
Tying your lines
Heres the knot for tying sleeved or 'Q' line............. http://www.powerline-sports.com/knots.html Heres a knot for tying 2 pieces of 'Q' together. http://brmrg.med.virginia.edu/knots/barrell.html I've been practicing the 'barrel' knot with thick rope & then trying it on a piece of 'Q' when I've got it down.
Gareth
Post by Gareth »
I've used the barell knot and it worked great. The beauty of Q-break it, tie a knot and away you go.
ThanksImage I wasn't 100 % sure if that was the right knot !!!
knot known to some as the fisherman, basically you tie two grannies around the standing end, opposite of one another. The only trick is to have the X's mesh, as you can tie them opposite of one another, 50-50 chance 8)
For added strength you can also do another wrap which results in the double fisherman. http://www.aqvi55.dsl.pipex.com/knots/f ... herman.htm
The tough part is once under tension, good luck trying to open the knot :?
Nice Kus...With thin line it's a one shot deal anyway.
so the bartender says hey arent you that piece of Q-line i threw out of here earlier? and the Q-line says "no im a frayed knot" :lol: :(
