Differences in OR Prodigy gen 3 vs 4 vs 5
Posted: Sat Apr 21, 2018 9:31 pm
by raztec
Can someone tell me what the main differences are between the OR Prodigy gen 3 vs 4 vs 5?
I've heard there are advantages and disadvantages of each.
Many Thanks
A
Posted: Sun Apr 22, 2018 1:10 am
by nanmoo
I'm sure Toddcares will chime in but the latest one goes to double ripstop fabric and a eliminates a bridle pulley making it more Roam-ish in the turns. Best one yet for sure but the last 3 gens are all go-to all arounders. The differences in the newest version are probably the most significant but it's not like it completely changes the kite, it's an improvement on a solid platform.
Posted: Sun Apr 22, 2018 8:30 am
by raztec
How about the valves used in inflating them?
I've heard there are significant differences and some you need to steer away from.
Thx
Posted: Sun Apr 22, 2018 10:47 am
by nanmoo
Oh yeah good point. The valve on the last two gens is the same hose-end clip-on high flow type. Tres bon. The one before that has the push in high flow with a screw cap. Never had a problem with any of them. Just make sure you don't crank the screw cap on.
Posted: Sun Apr 22, 2018 10:50 am
by raztec
Don't the gen 4 and gen 5 have a different valve system?
Posted: Sun Apr 22, 2018 11:31 am
by nanmoo
I think the earliest 4's still had the screw on cap which I had no issues with. Just don't crank the cap on. I believe the later ones have the valve that is on 5's and current gen.
Posted: Mon Apr 23, 2018 11:51 am
by GregK
(Todd correct me if I am wrong ) Gens 1 - 3 had the previous standard separate vinyl 11mm deflate and 9mm inflate valves.
Gen 4 has a single Boston valve which requires an adapter on the end of your pump hose.
Gens 5 & 6 have an adapterless speed inflate valve which connects directly to the end of your pump hose without needing an adapter.
Posted: Mon Apr 23, 2018 5:27 pm
Shite...I gots 3 of the things...valves all seem the same but now I feel I have "old" gear, where does it say the Gen#??
Posted: Tue Apr 24, 2018 11:40 am
by SmallWaveSteve
KUS wrote:Shite...I gots 3 of the things...valves all seem the same but now I feel I have "old" gear, where does it say the Gen#??
Definitely one of the older gens, you should probably upgrade. I'll dispose of the old ones for you
