Differences in OR Prodigy gen 3 vs 4 vs 5
Can someone tell me what the main differences are between the OR Prodigy gen 3 vs 4 vs 5?
I've heard there are advantages and disadvantages of each.
Many Thanks
A
Many Thanks
A
- Been thanked: 7 times
I'm sure Toddcares will chime in but the latest one goes to double ripstop fabric and a eliminates a bridle pulley making it more Roam-ish in the turns. Best one yet for sure but the last 3 gens are all go-to all arounders. The differences in the newest version are probably the most significant but it's not like it completely changes the kite, it's an improvement on a solid platform.
- GregK
(Todd correct me if I am wrong ) Gens 1 - 3 had the previous standard separate vinyl 11mm deflate and 9mm inflate valves.
Gen 4 has a single Boston valve which requires an adapter on the end of your pump hose.
Gens 5 & 6 have an adapterless speed inflate valve which connects directly to the end of your pump hose without needing an adapter.
Comox Kite Repair ( retired )
- SmallWaveSteve
