looking for someone to repair a dry suit neck seal
cdt
Post by cdt »
Can I get any reccomendations where to get my drysuit neck seal replaced?
Thx
WindePendanT
Post by WindePendanT »
If it's Ocean Rodeo, Ocean Rodeo.
If not, then Mec, or maybe Frank Whites dive shop.
snowwindwaves
Post by snowwindwaves »
There is a sports equipment repair business (think hockey and football equipment) in langford that can repair wetsuits as well. I will get the name
JasonD
Post by JasonD »
Frank White's
snowwindwaves
the business name is "stitched" 250 818 5827
they did a friend's wetsuit that was ripped.
Wooderson
Post by Wooderson »
Depending on the brand you can get new gaskets at MEC. I replaced a kokatat neck gasket with AquaSeal.
Cut your old neck gasket down to about 5cm remaining. Stretch it out over a pot or other object that will sufficiently hold it and stretch it.
I put my new gasket on the outside of the old gasket.
Scuff up the old gasket and the new gasket.
Apply aquaseal to the new and old gasket liberally.
And let it dry for a day or two.
This method may sound crude but it's worked wonders, the repair happend two years ago and I've got about 60 days + since then without problem.
AC
I
Post by AC »
If you get a new seal from Ocean Rodeo
After you take the old one off ,
You can use a two liter Pop bottle
place it in the seal against the suit to hold a nice
shape and tension on for a proper seal.
scarlet
Drysuit seals
Post by scarlet »
I live in Nanaimo and recently required ankle seals for my drysuit. Done in one day by George Klikach of Dive and Sea Sports. He comes to Nanaimo every 2nd weekend. Contact . Tel 604 524 1188
Unsolicited!
