Windsurf foiling
Never heard of that.TheLaw wrote:Are you sure they aren't semi-deep Tuttles.
slingshot says deep tuttle, and starbaord certainty looks like deep tuttle.
http://shop.fiberglasssupply.com/Sailbo ... _Race.html, should be the box on the left.
Agree that it depends on the set up where the balance point is. Generally it's front leg that controls lift, but once balanced I think it is usually somewhat even, like standing on a seesaw.nanmoo wrote:You will be all front foot on the foil anyways. So back there isn't going to be an issue. At least thats my guess from kite foiling where you are basically standing on your front foot.
But then try the canard wings I have (both provide lift, large wing in back)... The difference is immediately noticeable, your back leg will be super sore after an hour trying to keep the nose up on foil.
If bias is too strong one way or other, I think you can tinker with length of fuselage and angle of attack on wings (shims under one side or other) to balance them.
- thankgodiatepastafobreaky
I have a couple of Tuttle Boxes picked up by Windoc for me last year for mounting the foil masts in boards. I could part with one. Not sure how deep it is. I'll measure the depth when I can. They were a match to the Aguera board Tuttle Box used for kite race foil boards.
In my experience your pressure is mostly on your back foot for making the foil rise and then about %60 still on the back while riding. But I only know the Carafino and a couple home built boards. I can't see most of the pressure being on the front though. ??
Well that's really interesting about the foot pressure varying on different boards. Since this is the windsurfing foil thread I'd suggest looking for a foil design / mounting point that spreads the pressure evenly or toward the back leg as I have never had cramping issues or sore legs, just knees a little, and I have chicken legs.
Just a quick session on a foil, quite a bit of mast foot pressure, and little change make dramatic changes in the foil. The mast was long, but I'm wondering if that's easier, because you have more play and time with the trim of the foil before it lifts out... not sure because it's all I've tried.
So keith get out there man!!
I have the larger slingshot on an older Formula board. It flies earlier than the NP and LP but doesn't have the speed or stability. It also wants a narrower foot position compared to a "locked-in" race foil. I'm usually with my front foot to the inside and rear of the strap and back toes almost on center. Mast angle and front leg does most of the pitch control, rear mostly does the roll.
I'd like to get a smaller board for it but cheap ones with tuttle boxes have gotten thin on the ground. I might convert a PB board.
Foiling
So,
I am at Kootenay Lake.
Foil is set up on my 135L Roberts with the 24" Slingshot mast.
And 5.3M Revo
But it's dead calm. Haha. I did slog out in 1 knot and back.
Getting in lots of waterskiing and mtn biking instead.
Good news is I can now deep water start on a single slalom ski! Couldn't do that before.
And 5.3M Revo
- IMG_8059.JPG (156.04 KiB) Viewed 5210 times
- IMG_8050.JPG (97.49 KiB) Viewed 5210 times
- IMG_8060.JPG (169.8 KiB) Viewed 5207 times
Have the boat tow you onto the foil, I bet you could stay on the foil for a bit after, just DON'T have the driver gun it!KC7777 wrote:So,
And 5.3M Revo
- Atomic-Chomik
short mast
I'd have to say, i just learned on the slingshot foil academy and it was the bomb. I was foiling within the hour, then went up a size and was back up after second tack, now the long one and I'm down it. With the short masts, when you touch down you dont "go over the bars" endo style, you just keep popping up till you get the balance point.
Anyways, anyone see where the base plate gets mounted? I'm going to probably do a through bolts system as I've run out of fun money and i have the gear(for my SUP) to run a bolts through system.
