Moving in
- Has thanked: 21 times
- Been thanked: 4 times
I was at Esq Lagoon yesterday to look at the beach sculptures (amazing!) and the wind was pretty much west, off-shore 10-16 or so, but was surprisingly steady from the middle to the E end. I was thinking of this thread walking the length of the spit both ways. I'd guess mostly 12-14. It would have been no trouble for a floaty WS board and I think a kite could have worked the lulls without Hindenberging. My 112 l and 7.0 rig would have worked for sure. Flat water looked ideal for getting used to the foil!
- rvanderbyl
Here is how the master himself does it on Maui! Thank you Robby Naish! I watched him carry it like this all the way from the beach to the Uppers parking lot. Would help being taller if you want to avoid stubbing your toe.
- P1070091.jpeg (69.32 KiB) Viewed 4303 times
- Been thanked: 6 times
It's a pretty good proxy. If I see it gusting to 15-16 I usually go pump up a 12m for a fun kite-drift-kite session.grantmac wrote:Hmm I'd have thought in a westerly that the harbour sensor wouldn't give an accurate reading.
Being steps from the car is a major bonus with foil gear, I still haven't figured out a graceful technique to carry it in one piece.
Ray that looks like a taller mast that I metre or maybe it's just perspective cuz it's uphill on the beach and closer to the camera. Still looks like a good way to cut your foot in half. Stubbing your toe? You could shave on the trailing edges, amputation actually more likely. I'll make two trips if I get one!
- rvanderbyl
My neck is happy with a two piece carry to the shore, then I flip the board and hold the foil mast while trying to keep from dragging the nose. Both my foil and board are heavy.
But I was out last night in 12-15kts with an old Naish 5.5 and having a great time. Early 2000s sails seem built to foil, tight leech and mono. I think I might add a cam to that one and possibly a few tube battens.
Got a chance today on the ocean side of the lagoon. Yep Esquimalt harbour sensor is a good proxy in NNE but the lulls are DEEP. Definitely nuke and puke but at least you can see the gust coming, bit better way out in the channel from the harbour.
Fun enough on a foil, super easy carry, dead flat and zero kelp.
Very tempted to try some hammer down slalom action in the lagoon at high tide in a SE.
-Grant
-Grant
