Wing Gloves - Winter
slake
Has thanked: 8 times
Been thanked: 6 times
Post by slake »
Been thanked: 25 times
Re: Wing Gloves - Winter
Post by UnusuallyLargeRobin »
Has thanked: 27 times
Been thanked: 16 times
Post by Bobson »
ps. I do secretly wish I could Wing. Maybe, one day. :-$
Highrocker
Has thanked: 10 times
Been thanked: 24 times
Post by Highrocker »
The following applies:
Warm wingfoil wishes.
velcro elastic cinch straps
TunaCan
Post by TunaCan »
MtnarG
Post by MtnarG »
Gyro Beach Board Shop only has the NRS Mitts in size XS
slake
Post by slake »
slake
Post by slake »
jessematthewman
Post by jessematthewman »
jessematthewman
Annnnnd looks like vissla stopped making the 1.5mm. Lame. It was (is) honestly the most durable thin wetsuit glove i’ve ever owned and it only has one repair after a full year on the water, and that’s from scuffing my knuckles on some barnacle… :(
slake
Post by slake »
UnusuallyLargeRobin wrote: Mon Nov 20, 2023 8:47 am I am about to receive these Ion glove/mitts
slake
Post by slake »
