Wetsuit thickness summer / winter
- abetanzo
Hi just wondering what wetsuit thickness to get for summer kiting? thinking a 4/3 should do??
I already have a dive / snorkel geared Pinnicale semi dry Merino lined 7mm wetsuit which I will most likely use in the winter.
7mm merino suit?! I think that should be pretty warm...
4/3 will keep you plenty warm I should think. I wear a 4/3 in the ocean during the summer, but it's ancient and probably only as warm as a 3/2 at this point. For the most part that is warm enough, and I get cold easily.
Depending on your temperature tolerance and how late into the spring you are comfortable with that 7mm unit you may even want to go 3/2. Depends how much time you spend in the ocean vs. Nitinaht.
- Sandy Beach
- Has thanked: 2 times
Re: Wetsuit thickness summer / winter
Abetanzo, If you venture over the hump to the central hot spot valley of Vancouver Island, Port Alberni (just 45 minutes west of Parksville), the Alberni inlet water boasts the warmest ocean temperatures for kiting on the island.abetanzo wrote:Hi just wondering what wetsuit thickness to get for summer kiting? thinking a 4/3 should do??
I already have a dive / snorkel geared Pinnicale semi dry Mernino lined 7mm wetsuit which I will most likely use in the winter.
Many of our local kiters and windsurfers can play in just their bathing suits, rashies and/or shorties for the summer hot months.
Not to mention the predictable, strong, consistent thermal winds and controlled kite launch and landing from our day use park's pier, formerly known as Wild West Watersports.
Lots of exciting events in the works for this summer on the waterfront in Port Alberni, 2012 (centennial year for the town).
Mark my words, PA has similar characteristics to Squamish and Hood River over a decade ago, and we will see huge transitions over the next few years of this 'town in transition' from heavy industry to more recreational/tourism based.
Check out the <a href="/http://www.bigwavedave.ca/webcams.php?cam=11 " target="_blank"> Pt Alberni Harbour Quay webcam </a> to track wind/weather conditions as the season starts to approach, now that it's the first day of spring
Thank-you, BWD for this invaluable resource (webcam and weather meter).
More information to come!
That should be fine for summer use. The suit I run the most is 5/4/3 with 3/4 legs and it's a bit loose so not as warm as it could be.abetanzo wrote:Hi just wondering what wetsuit thickness to get for summer kiting? thinking a 4/3 should do??
- voodmon
wetsuits
For Juan de Fuca strait a 5/3 preferably hooded, the water temp is only about 1 degree warmer in summer a balmy 9 "C or so and gordons can be 10"C air temp in summer when the fog rolls in, always better to be too warm than cold, a 3/2 would work for nitinat, but I wouldn't waste my money on a 4/3 for the straits. Personally I wear a smoothskin hooded 6/4 in winter and a regular nylon 2 version of the same 6/4 in summer. The point to always remember is.. that if you break down and are in the water swimming for any length of time without a hood or thick enough suit you will become hypothermic very quickly 15 mins or sooner and then you die!
Re: wetsuits
Regardless of what wetsuit you wear it's good advice not to ride away from shore farther than you want to swim and don't hesitate to eject all your gear and swim as fast as possible if need be.voodmon wrote:that if you break down and are in the water swimming for any length of time without a hood or thick enough suit you will become hypothermic very quickly 15 mins or sooner and then you die!
You can always buy new gear.
- Been thanked: 5 times
sounds about right. Once really warm weather hits, Nitinat, Port Alberni, Pipers, San Pariel, etc can be sailed in a shorty.
[edit] how did this go from being the first reply to about 20th when I hit 'submit'?? Got interrupted by damn work!! Voodoo is right about staying warm at Cook or Gordos though.
