Skate-sailing
Skate-sailing
This is old skool fun, but I'm really surprised no one does it anymore, namely skate-sailing! Just rig up an old beat up 5.0 and mount it to a skateboard deck (longer is better) and go session the cruise ship port area in Victoria. Any wind direction works; you just need about 10 knots of wind to have fun. The same muscles get used as in windsurfing and there is the added challenge of going without a harness. Switch stance moves can be learned quickly and things like hoss-tacks, 360s, duck jibes, ghost jibes etc can be learned in a session. You are building muscle memory for the water, so you stay much more sharp than sitting around reading posts like this in between sessions
RD and I have had great sessions skate sailing and really feel the benefits of the work out. Try it out! I had a great session at 12pm today solo. Learned switch stance clew first flakas today
- Russian Dood
Ross,
I've got a 5.5 in really good cond. that you can have if you like. Needs a 430 mast. I've got a mast ext for you too if you need it.
Keen, you can go pretty cheap on the deck, but you'll have more fun with a good set of longboard trucks (stable at speed) and big 70mm wheels. The trucks and wheels can be spendy, but cheaper ones work well enough too. Like I mentioned earlier, find a tired mast, 5.0, and old boom and go for it. Pavement is harsh on gear (and skin) so wear some protection (RD prefers buttless chaps and a time trial helmet). A sweet acid washed jean jacket, old leiderhosen and a mullet wig work for me.
Today was sailable again. Dry NE winds are really fun.
skatesailing
I remember smaller sails such as 4.0 and 4.5 working very well for skatesailing, 5.5 might be a bit big. Once you have enough wind to get moving on a skateboard your boardspeed adds to your apparent wind. Jibes are almost effortless because the board does not slow down as it does in water. With just a little boardspeed it is also very easy to sail close hauled into the wind which allows for more freestyle off the wind. Smaller sails would handle better for freestyle, after a few hours practice you can use your regular sails and booms. If you are still dropping your sail, you should quit, falling is just not an option. You should be balancing your body with the weight of the sail with just your fingertips.
I also remember using an empty styrofoam cup on the pavement for a wind gauge, lay it on it's side if it rolls there is enough wind to rig up. Place it upside down on the pavement, if it blows away, there is too much wind for skatesailing, "time to go to the beach".
As for changing tacks I never bothered to switch my feet over, just a little twist of the body allows for sailing on the opposite tack. Not being a true skateboarder I found it safer not move my feet.
With skatesailing you need a large smooth area of pavement, a neighbourhood road just isn't big enough. If the pavement isn't smooth enough the vibration will numb the bottom of your feet after a half an hour of cruising around. Nightime skatesailing in a well lit mall is a blast using the lampstands to jibe around.....until the mall security trys shuting you down.
As far as safety goes, a helmet and protection for hands if you were to fall would be a must. In the mid-80's a well known US windsurfer / boardbuilder (Craig Stoetsel..... sp?)died skatesailing. Be careful and enjoy!
- Russian Dood
Hey TomS
I hear ya. Almost killed myself a few years ago on a regular sketeboard with the sail switching feet. Knocked myself out cold for a few sec.
That's why I think sailing on a regular skateboard is not such a good idea. Logner board would be an order. I found regular long boards being too long (that's just me). That's why I built my own. And yes I do use 4.5 it's enough for me, but Winddoc is a different story all together. His mullet wig creates too much drag that why he needs bigger sail. Also he didn't mention that but he wears prosthetic beer gut for frontal protection - that might slow him down a little as well. But what do I know I am not a rocket surgeon.
Cancer must die!
Skate sailing
Hi,
Looking at some skateboard decks on eBay....would you go for a 60" or 48" deck?
Thanks,
Keith.
Thanks,
Keith.
- Russian Dood
