Mast massacre!!
Mast massacre!!
I need to turn my 400 RDM into a 370.....I figure a nice clean cut with a chop saw should do the trick.
Yes I know it will alter the IMCF, and pretty much make the thing worthless, but aside from these minor drawbacks
does anyone have any comments or suggestions.
- Been thanked: 12 times
don't do it
extending the turban with another strap has the same effect as cutting the mast, probably a better result. Or: get a small sail that takes a 400 (some rig down to a 3.3) or buy a 370, check RainX's new rig, nice
Cutting your RDM cleanly
If you're cutting - use a diamond blade with water (tile saws work best), high speed on the blade, moderate feed, one pass. Regular carbide toothed blade will delaminate composite internally and will burn epoxy - water will help save your lungs and eyes - the smoke is toxic! Protect your lungs and eyes with a mask and goggles in any case - experience talking!!! Sand inside and outside edges after cutting with 400 wet paper, a quick pass will do it.
Geoff (Profile Composites - we cut hunderds of these things every day)
- Starboard Steve
Thanks for all the advice: 3 cuts to 1 no cut, however I think Kus may have talked some sense into me....
Whats the easiest way to extend the turban length? Do I need to sew another strap onto the existing, or is there another way?
It's a Revo 3.8, if anyone has specific recommendations please let me know.
Sent you a PM, water or tape knot, MEC or Bosun's will have strap material
http://ozultimate.com/canyoning/knots/tape_knot/
A Revo 3.8
I just looked up the specs, it's got a luff of about 383, only 17cm of mast sticking out, that's nothing
It should rig just fine dandy on a 400
A Revo 3.8
Yeah Kus you are right according to the specs it should rig on a 400, but it just doesn't.
I think the previous owner must have put a smaller strap on it, and rigged it with a 370, so as not to have the mast poking out.
My guess is there is a slight performance advantage to this.
Thanks downwind dave, if I cant get it to work with Kus's suggestions, I'll check out the Duncan cobbler.
thanks again guys for your help.
- Russian Dood
