Website loading problems
- Has thanked: 42 times
- Been thanked: 55 times
Kite Kook: Has anyone else had occasional difficulty loading this site over the last few days? It just seems to hang without loading for me, yet no problems loading all other sites... - Monday June 15, 5:15PM
Jl: I have ... Telus ? - Monday June 15, 5:18PM
Mortontoemike: Shaw too. - Monday June 15, 5:27PM
Kus: me too, both Shaw & Telus, mostly homepage, I think it's Islandnet's server - Monday June 15, 8:41PM
There are a few things that could cause this. The bigwavedave.ca domain name is hosted by easydns.com and the actual website is hosted, in part, by islandnet.com. When things like this happen they tend to just blame each other. It is also very difficult to diagnose since it doesn't last very long.
So the next time it happens, please try a trace route and note the date/time and post here:
If you are using XP, go to the Start menu > Run > then type
<b>tracert bigwavedave.ca</b>
copy and paste the results here.
loading
I'm on Mac on shaw and having trouble, unless I load a web cam address first then go to home page. Home page must be issue.
Unable to load homepage
I've been experiencing the same problem recently. Unable to load the homepage unless I open a webcam. Fine this morning and now but unable to access the site around 4pm today. I have had the same problem a number of times in the past. Switched to Shaw this month after years of Telus torment. Thanks Dave for the service you provide to the rest of us ....it is hugely appreciated
Thanks everyone. Sorry, it's a very annoying problem. I'm guessing it's an islandnet problem with how PHP pages are being handled. The problem is that all other islandnet pages I visit are fine. I will talk to support again in the morning.
When it happens next can you check these two pages:
1. http://www.bigwavedave.ca/images.htm => loads yes/no?
2. http://www.bigwavedave.ca/latest.php => loads yes/no?
I suspect 1 loads okay but 2 doesn't?
For the trace route: right click > select all > then hit enter. But you only need to post it if the trace does not end up at cluster.islandnet.com
It happened again late last night.
This is exactly what happens to me: 1 loads, 2 doesn't. I tried the trace, but I too had trouble with it disappearing when it finishes. I tried Alt+PrtScreen and caught this when it was about 3/4 done.1. http://www.bigwavedave.ca/images.htm => loads yes/no?
- Been thanked: 12 times
tried for quite a while yesterday, usually hitting reload repeatedly ends up finally loading the page or exiting firefox and then restarting works for me.
Yes, cams came up, no go on the forecast page OR the forum page, no go for over an hour. Gave up.
Good way to ease off the website, cutting back on the addiction
