stripped screw
- SaltSpringKiterPeaceGuy
stripped screw
Hi folks,
Got a mechanical issue with my mako. the inside screw is hole is stripped. i screw it in and it keeps turning without tightening. It's still pretty tight in there, but just wondering if the board is safe to use...........Thoughts much appreciated.
Kevin
If your happiness depends on money, you will never be happy. Be content with what you have take joy in the way things are. When you realize you have all you need, the World belongs to you.
- Been thanked: 12 times
u could try to fill with epoxy and clamp the screws down until it sets or drill it out slightly, retap, use 1mm larger screws. or replace the inserts by epoxying new ones in, units available from places like windance or fibreglass shops in the Gorge/Bingen.
helicoils may rust/corrode but u can try that. Any automotive shop will be able to do THAT. never heard of a ski shop doing this but maybe snowboard shops. if they have a choice, stainless or brass of course but i don't recall ever seeing that available. u can buy helicoil kits at Crappy Tire or Lordco
I just repaired a few similiar holes on my sailboat and the method I used was to first clean and/or drill out the hole, fill the entire hole with Marine-Tex epoxy, wait an hour or more, drill the holl out slightly undersize, tap it, then screw away. So far so good and I did some research prior to undertaking this method.
- Windsurfish
Marine Tex is Magic
This material is available from any marine supply - and tapped threads work with it. Another product that might work is JB Weld, available at Automotive supply shops. It can repair cracked heads in diesel engine.
there's lots of interesting suggestions and i thank you all for them! i think i'll go with the marine tex nanmoo! thanks, what a community. i love the island!
Kevin
I really don't have the facilities nor skill nor experience to do this, but i hope that someone will...........and if not i'll give er a go with the limited resources here............
Kevin
- GregK
I had a similar problem on a used Lightwave board I bought last year. Not only were some brass inserts in that board stripped, but the bond between board ( deck laminate and foam core ) and insert was gone on a few others.
Inspect the threads closely with a bright light. If the threads look OK but a screw keeps turning after it's hit the bottom of the insert, then it's the bond between insert and board.
I fixed it by pinning the spinning inserts with short 1/8" brass rod in two places held in with marine epoxy, plus more epoxy injected into the perimeter of the insert through small oblique holes. This secured the inserts to the board. Then I tapped the stripped inserts 5/16 " - 18 tpi ( threads per inch ). Big screws, but it's all held up fine for over a year now.
What-ever it needs, hope it works out. If you want to ensure you never strip an insert screwing down a foot-strap, Locktite in ~ 1" long set screws, then hold your footstrap on with nylock nuts - only needs tightening maybe once a year, and no more fighting the footstrap while you try to screw it down without stripping inserts.
Looking at this post after I wrote it, it's probably not clear why I pinned the loose inserts. From the side, the single-point inserts used by LightWave are like a fat 'T", about twice as big in diameter at the top third than the lower 2-thirds to maximize area in contact with the deck laminate but minimize weight. I drilled my pin holes out at very close to the outer top diameter, through the T and the core foam below, and just hitting the bottom laminate. Pin holes were oriented at 0 and 180, epoxy injection holes at 90 and 270 degrees. Now that I'm thinking about it, injecting epoxy into the little holes didn't work well, so instead I filled the pin holes with epoxy, plugged the insert threaded hole with a waxed screw and put epoxy around this opening, then used vacuum from my shop-vac to draw the epoxy around the outer surfaces of the insert. This worked really well. Once I was sure I had epoxy all around the insert, I added a little more to the pin holes and inserted the 1/8 pins, cleaned up the excess epoxy around the holes and let it set - problem solved for a good while I hope.
