CB etiquette
Paul L
CB
Unread post by Paul L »
This is from the Maui Kiteboarding Association. Everything one needs to know about ROW's is on this web site....
KITEBOARDING PRIORITY RULES
Kitesurfers have to cooperate with other water users, and there is a system of priority the helps establish hierarchy for right of way.
Windsurfers, and Other Sailing Craft. Situation: When you encounter another sailing craft, you should give way.
Definition: A kite is technically a sailing vessel, BUT the lines, large window, and unpredictability, generally make them incompatible with operating close to other sailboats.
What to do: give way to other sailing craft, keep large buffers between you and other sailing craft. Moderate you speed when close to other sailing vessels, and ride in a predictable pattern. Never fly your kite over a windsurfer or sailing boat. you could clip their mast or worse. Otherwise you should observe normal sailing rules.[/quote]
CB issues are very site specific :idea: good to review the wave section tho
rookieRyan
Unread post by rookieRyan »
Should make a big sign/map at C.B with the rules on it.
BUMP 8)
heffe222
Starboard / Port Tack
Unread post by heffe222 »
Thanks for the bump, KUS, and for the rules link, JL, but no wonder there is confusion about right-of-way (under ordinary sailing conditions). The Maui Kiteboarding Association seems to have conflated Starboard and Port tacks in their rules. ???
For definition, see: http://en.mimi.hu/boating/starboard_tack.html
In the interest of safer wind sports
:wink:
Re: Starboard / Port Tack
:wink:
Maybe I missed something. Where in the rules have they conflated the two tacks?
:wink:
Nope don't think so,
"The kiteboarder on port tack gives way to the kiteboarder on starboard tack."(Maui kite rules) has the same meaning "starboard has right of way over port"(normal way of saying??)
heffe222
The rules are understood and correct, but what I find confusing is that the Kiteboarding Association seems to describe a starboard tack as a port tack - n'est-ce pas?
scarlet
Unread post by scarlet »
It does make sense. Look directly at the widow. If your kite is on the right side between 12 and 3 you will be heading to the right with the wind coming over your right shoulder ... A STARBOARD tack. Similarly, if kite flying on the left side of the window between 9 and 12 you must be heading left with wind coming over left shoulder.....PORT tack
scarlet
Make that window not widow :oops:
Same thing as windsurfing, left hand forward = port, right hand forward = starboard. Unless your riding backwinded, sliding etc,
ambientrax
right of way...
Unread post by ambientrax »
I treat every kiter / windsurfer the same on the water, even if I have the right of way, I generally assume the other sailor has no clue as to who has the right of way, so I am just cautious and give the right of way. give and take... the right of way is something that should be given not complacently taken.
Has thanked: 24 times
But we should also be expecting newbies to learn quickly and minimize confusion. Some new car drivers may not know that at intersections a yield or stop sign means the drivers on the other road have right of way. But we don't expect that. If you have a through road and the cross streets have stop signs or red lights you drive at a constant speed and don't hesitate. If you were to drive like every intersection is a 4-way stop, it's going to cause more accidents overall. Yeah, you still need to do your best to avoid the person blowing the stop or red light. Sailors had avoidance rules way before those on the road figured they needed them too. mariners created them because collisions were devestating. Still holds true.
Has thanked: 4 times
I agree - it is important that the "rules of the water" are understood and followed because it is the indecision that often causes the crash / incident. Respectful and friendly instruction / direction would go a long way to accelerating the knowledge of newcomers (or even experienced sailors who don't seem to care or are oblivious). I am sure I inadvertently get it wrong from time to time and would rather the other sailor let me know / remind me than get p***d off or worse.
