How do you convert North 4 line bar to true single line flag
kirk
Unread post by kirk »
How do you convert North 4 line bar to true single line flag ? The hole in the iron heart is too small.
Atomic-Chomik
4line conversion
Look it up in Kiteform. Has been covered in depth.
kirk
key question is TRUE single line flag. North quad only has a limited single line travel due to not being able to pull line knot through the small lion heart. Has anyone figured out a mod that allows bar full travel on single line. The north quad single line flagging works fine on the 9m eveo because only 4m or travel is needed for full flag. Flag the 12m and it in not 100% flagged, bigger kites are even worse!! I like the bar and would like to mod it for safety.
I have the 2018 Ocean Rodeo Pilot bar that has a true full single line flag system. Can an mod the North to do the same ?
