Mast repair
Royce
Mast repair
Post by Royce »
Tried an experiment today I had a 460 75% carbon powerex SDM mast that came with some other gear that I bought and it was broken below the furrel so I cut the mast off below the Ferrel. Chucked it up in the metal lathe and turned down the old top 6" of the mast until I got to the glue, then ruffed up the inside of the lower mast and epoxied the Ferrel (with electrical tape as a stopper and for easier cleanup)back into the lower portion of the mast, assembled mast and layed it into a peice of angle iron to cure straight. Anyway it might work but it's a 445 cm now
good job saving a mast from the landfill. maybe just stay close to shore the first couple sessions. :D
Re: Mast repair
I have a 430 100% carbon one you can try that with :twisted:
