2nd Wing board options
Has thanked: 27 times
Been thanked: 18 times
Post by Bobson »
I'm going to continue Wingfoiling again in March/April. I'm thinking it will be time to get a smaller Wingboard fairly soon after that. I currently have a 130 litre (6'x30")KT Wing Drifter which I will start with again when I get back to Winging. I'm 225lbs currently and would like something that will at least get me back if the wind shuts down so nothing too small. I was thinking at least 90-100 litres. I don't mind pumping as it's a good workout and I don't mind schlogging as long as I'm not hip deep in the water.
This post is asking for your opinion for a next Wingboard for me to get. A midlength board or just a smaller sized regular shaped Wingboard? Some of you have been Winging for a while now and are on to your 2nd or 3rd board. I'd like to know your thoughts and if you'd get a different 2nd board and why. Also, any Wing boards you are totally stoked on and why.
I will keep my Windfoil gear but I'm going to focus on Winging until I can consistently make my jibes. At the end of last summer I was making 70% of my jibes. I have 4,5 and 6m Wings and a few different foils 700cm2, 1263, 1700. I'd like to be able to go out in 10-30kts.
I'd like to hear your opinion and suggestions. And ........ GO!
Has thanked: 8 times
Re: 2nd Wing board options
Something around body weight to perhaps 10l under and a bit narrower than what you've got would be a solid plan. For me at 95kg and 85L taxies pretty easy in light wind and a 100L is only a touch easier. In both cases if it's really light sitting down saves a lot of energy when there is chop.
Full disclosure I'm selling a 101L NSP which would fit those specifications and I'd be happy to lend it for an extended test ride when I'm next in town.
What are your riding goals for the summer? I'd say if you want to try some jumps that would be the only reason to go with a short and wide wingboard. Or if you're planning on riding mostly the lake and inlet thermals.
Then you can get away with a smaller short/wide board. Otherwise, midlength. The problem is a 100L midlength is still a huge board, it'll offer you deeper touch free carving and tacking, but that's about it over your current board. Tough call, I'd say get your jibes closer to 95% then demo some smaller boards in the 80L range.
