Crash on Forecast
We want your feedback: comments, complaints and suggestions for the website
Has thanked: 24 times
Crash on Forecast
Several machines I use sometimes crash I. Explorer when the forecast page is loaded. Marine forecast is OK, but when I page down it crashes on the 'Victoria' forecast. I note that this also happens when I load "cities and towns" forecast page from Env. Can directly. I think it happens on a range of platforms, from Windows 98 to XP Pro. No, just checked, it doesn't do it on XP. Happens every couple of months, usually lasts a day or two then goes away. Weird. Does this happen to other people too? Anything I need to do at my end, or can BWD site be altered to avoid the crash taking down the whole program?
boobhunter
crash
Unread post by boobhunter »
It happens to me all the time....... :D usually after I've been surfin tha porn
Seabiscuit
Unread post by Seabiscuit »
You can try the usual. Make sure temporary internet settings are set to every visit to the page. As well delete the contents of your temporary internet files folder as well as the contents of the windows\temp folder. Files here can become corrupt which can cause this problem.
Tx, Seabuscuit! just tried it but it hasn't helped. My settings had been changed to 'automatic' from 'every visit', but still doesn't work.
mortontoemike
The solution is straight forward, trade your Windows machine in for an iMac and use Safari.
Russian Dood
Unread post by Russian Dood »
Before you do that make sure you updated your browser. Or install Firefox - never crushed on me either on Windows (Me/XP/2000) nor Linux
Has thanked: 42 times
Been thanked: 55 times
Re: Crash on Forecast
more force 4 wrote:Several machines I use sometimes crash I. Explorer when the forecast page is loaded.
Hey Mf4: Sorry for the delayed reply but I've been out of town for a week. Like Russian Guy says, have you done all the Windows updates or browser updates? I haven't seen this before, but I use XP. It sounds like it is something on the EnvCan page, I'll look at the page and let you know if I see anything,
dave
More suggestions...
Hey Mf4: Try this too:
Start Internet Explorer
Empty the contents of the Temporary Internet Files folder. To do so:
On the Tools menu, click Internet Options.
Click the General tab.
Under Temporary Internet files, click Delete Files.
When you are prompted to delete all temporary Internet files, click OK.
In the Downloaded Program Files folder on your hard disk, remove the files that are listed as either Unknown or Damaged. To do so:
Under Temporary Internet files, click Settings.
Click View Objects.
The list of program files that are downloaded to the SystemRoot\Downloaded Program Files folder on your hard disk appears in the Downloaded Program Files window.
In the Status column, note the files that are listed as either Unknown or Damaged. Remove these files. To do so, right-click the file, and then click Remove.
When you are prompted to confirm the removal, click Yes.
Close the Downloaded Program Files window, and then click OK two times.
