Wet Suit For Victoria !!
MarcSnap
Post by MarcSnap »
Well I am about to go buy a wet suit and was wondering what would be the best one to get for Kite boarding ??
I heard about 1 peice suit with 4 mm all around with 3 mm at elbow and knee area
or
5mm all around with 4 mm at elbow and knee area
are these good enough to not freeze after 1 hour in the water,, and which one would be better???
Gareth
Post by Gareth »
The best is a 5/4mm surf suit with an attached hood. That could probably keep you going all year. If comfort and warmth are your ultimate goal, you could try a drysuit in the winter. Most kiters around here use an Ocean Rodeo Pyro.
hope that helps,
This 'thread' has some suggestions: http://www.bigwavedave.ca/phpBB2/viewtopic.php?t=2535
MarcSnap
Post by MarcSnap »
Sweet thanx for the suggestion link.. Much appreciated
Globetrotter
Post by Globetrotter »
i wear a 4/3 quicksilver year round, 2nd one i've had -
you can get them off of ebay and shipped for under 150 cdn (new)
mmm wind
