Dimensions for a land sailor
KC7777
Unread post by KC7777 »
Hey,
I have found a pair of old wooden water skis in mint shape. They are 7" wide x 65" long.
I'm thinking of making a custom longboard that can be set up as a land sailor for windsurfing.
Anyone out there with a land sailor.....my main question is where to set the mast base relative to the front trucks/wheels.
I'm thinking just in front of the front wheels for the mast base position.
Below in the picture (for reference that is a 38" longboard skateboard beside the waterski). I have just placed the wheels and mast base roughly where I think it should go (no holes drilled yet). Does it look OK?
I'm also thinking that this waterski is long enough that I could make the dimensions (eg. mast foot distance from tail) roughly the same dimensions as my Goya One?
Thoughts? Should I cut the tip off and make the overall length shorter? Does anyone have dimensions for a land sailor?
I have 2 of these skis.....so if I mess up the first one it will become a skateboard.
Thanks,
moreso than a board on water (since that can pivot much easier than sticky urethane wheels on asphalt), it depends on how big of a sail you plan to use.
KC7777
landsailor
Thx moo.
PS - it will have four wheels so can I call it a quad?
K
firstonlastoff
Unread post by firstonlastoff »
ya gotta consider friction as a primary factor for placement of that universal, (bring the drill with you), and of course tribune bay may require bigger wheels and trucks..., and a cool concept for black-top (or possibly hard sand) sailing could be a floating universal base, to allow foot work carving while preserving sail&mast foot pressure - I've got a plan!
KC7777
landsailor
Hey FOLO,
This would be strictly low wind, small sail (4.2?) on a big flat blacktop parking lot with skateboard wheels.
Will likely leave the nose a bit long and try a few positions.
K
that looks like my stick, minus the flip tip. i put the mast base about an inch ahead of the truck, works fine. and leave the ski rocker there, it looks boss!
8)
KC7777
Wind skate
This guy sucks....check out around 1.46
https://www.youtube.com/watch?v=cmfrn4Eesno
skipro
landskate
Unread post by skipro »
KC could you put a big swivel roller on the front so it is more like actual windsurfing? rear wheels would grip like a fin, but the nose could swing?
Might not work for carving gybes etc. like a skateboard would.
don't hurt yourself for actual windsurfing. Land is harder than water.
Cheers,
Craig
