Weather Station I want to donate to a good location
- Starboard Steve
- Has thanked: 34 times
- Been thanked: 40 times
It doesn't need an internet connection, only if you want to share the data. It comes with a digital display to show you the readings. You can use it on its own and just look at the data, or hook it up to a PC and store the data, or hook it up to your router and send the data to a website, or use a cellular modem and send the data to a website.
thinking about wireless internet connections at Clover. The ShawOpen Wifi signal is strong at Cook and Dallas, and I think Shaw has repeaters all along the Dallas waterfront, so maybe a decent signal at Clover? Good line of sight for sure. With a Shaw internet account you are allowed to connect 3 devices. I would donate one of my 3 Shaw wifi device connections if this is technically possible.
It's possible. I'm actually using the ShawOpen wifi signal at Island View to upload the data from the weather station. The problem is that it needs AC power. I connected the digital console of the weather station to a wireless bridge and that connects to the wifi. But both of these things need power. I suppose it could be powered with solar and a battery but that would have to be built.
The wireless range on the weather station to the console is up to 300m. So we may be able to get a signal to one of the houses that are closest to Clover Point and then upload the data using ShawOpen. We'd have to find a willing person and then test it out. If we get the go ahead from the city it may be worth a try.
The cellular modem is pricey but may be the simplest solution.
What about on a cabin at point no point? They have a few cabins right on the water, and structures you could mount to, and run cables up.
you'd have to be crazy to break in there and destroy private property
It just seems odd to put it at clover when we have ogden and trial right there
But I suppose sheringham isn't far from point no point either
- point no piont.JPG (59 KiB) Viewed 3073 times
We also have the Gordons beach weather station & cam. Cell service is 'roaming' West of Sooke In this N. wind Cordova bay becomes interesting. How about approaching the http://www.beachhousevictoria.com/
that has been kicked around for a Cam, given the wind hole below the access there tho it is likely not going to be very accurate for the weather station and IV and Kelp are pretty indicative of outside wind. Maybe a home on Parker for this one or directly on the beach at Agate?JL wrote:We also have the Gordons beach weather station & cam. Cell service is 'roaming' West of Sooke In this N. wind Cordova bay becomes interesting. How about approaching the http://www.beachhousevictoria.com/
We do get about 6-8 NE days there a year only tho but who knows now....maybe this is the new CB afterall
- rvanderbyl
