SUP leaks
- tempy
SUP leaks
I have a question about "odd" apparent leaks on my SUP.
I noticed a weird "bubbling" inside my grab handle and also inside the leash plug on my SUP when it was out in the sun at Nitinat this year.
I assume it was because of a slight pressure build up in the heat. I released the vent plug and it disappeared.
It got me thinking though - if air was escaping, couldn't water get in? And then I tried to see where the hole was. It is impossible to see, and the bubbles were coming from inside the grab handle, and inside the leash plug.
has anyone had a similar experience? What do you suggest I do about it.
My Naish Nalu had the problem, as did my Starboard (only the leash plug on the starboard).
Boards are too old for a warranty claim, although it sure seems like a design defect rather than something I did, given the leak area.
Thanks in advance for any advice.
does your board seem heavy? It's easy to find a leak by putting your board out in the sun but this time of year good luck with that. you can take an old schaeder valve cut off a tire tube and thread it into your vent hole then GENTLY use a bike pump to pressurize your board a couple psi, just enough to see if you get bubbles. handle is actually a common spot to get a leak, it's a hard spot where the foam can get crunched down all around.
