Best Wetsuit Liner Type/Brand?
- Has thanked: 21 times
- Been thanked: 4 times
Well seeing there is no wind, I'll have to buy some equip. On the (maybe incorrect) assumption that there will be wind before spring, I'd like to add a wetsuit liner. I'd really like a breathable drysuit, but ... There seems to be two or three kinds in the local surf/dive shops -
nepoprene with microfleece lining,
spandex,
spandex with fleece
and spandex? with titanium reflector stuff.
Anyone know anything about the choices. Prices seem to range from about $80 to $130 for the titanium.
spandex,
spandex with fleece
I bought a 1mm pro limit top from Windance and use it under my whites wetsuit. helps a lot for winter warmth - you don't feel the flushing as much.
http://www.windance.com/default.asp?win ... tem~PL2CVL
The only thing is the extra rubber makes you feel like the michelin man.
warmth
Hey, with respect, I think you guys are all talking about filling the void spaces in your wetsuit so water cannot flush your heat away....anything, your granny's old socks, will work for that. You don't actually get mega cold when you are sailing along cuz you are working all the time, only when in water and getting flushed.....As soon as you add enough bulk, like my o'neil top with hood for 2-3 mm, you DO feel like Michelin Man and won't be able to sail worth a shit. I'd rather try flex seals around your ankles/wrists and a good PFD to keep arms and neck above water.
Good advice if you want some: Get a dry suit or a good non-leaky steamer, for god's sake or stop sailing in winter . People blow several grand on gear but won't shell out $400 for a potentially 10-20 year suit. I believe you turn into a liability in this water temperature without it! I know. I worked in the business What's your life worth?
warmer, not safer
Hey, read this again, this mighta sounded harsh for someone looking to get warm and fuzzy. Okay okay, any wicking fleeces work to keep WARMER, but like I said, few things will kill ya faster than cold water....buy the suit. Kus
Hey, Kus, thanks for the tone down. And thanks to the other posters for earlier recommendations. I bought a new 5/3 steamer last spring, and it is WAY better than anything I've ever had. It has good neck seals and the cuffs are still reasonably tight, so there isn't much leakage -- still not a drysuit though. I'm just looking to add some extra insulation to the core area. I can't sail worth a shit anyway, so that shouldn't matter too much - I'm winter sailing to try and get more time on the water than I seem to on occasional one day or weekend trips to Nitinat. I've added booties and open palm gloves this winter. I did get pretty cold on an earlier session (esp. hands, which don't matter too much for hypothermia, but do when you wake up in the middle of the night with both your forearms and hands completely numb and have to shake them for a minute to get back feeling/circulation......). That chill could be traced to spending 15-20 minutes in the water on the first run trying to reattach the boom (memo to self - triple-check all gear attachments). The PFD might also be a good option, but I've already ordered the surfsuit from MEC. I've also been following the cold water sailing threads in recwindsurfing, and read the cold water issue of Boards magazine, and have a long term interest in hypothermia, so I'm pretty knowledgable about the risks. Now if only we can get some decent wind!
hands
hey, yeah, just having one of those days
taking along a thermos with warm or hot water and heat your hands up after the first real chill a few runs into things tends to take the edge off I find, nvr found that gloves worked too well, get forearm cramps. Cheers. Time to mellow, I know. [smilie=drinkofbeer.gif]
