Windsurf Foiling Discussion
elt
Unread post by elt »
Keen
Unread post by Keen »
Wow!
tweezer
Has thanked: 30 times
Been thanked: 27 times
I joined the Flog Life
Unread post by tweezer »
Cheers
Mark
Yup, withdrawals here as well. It doesn’t help that I can see all the mutts on CBTV while I wait around for son #2 soccer game in Oak Bay ...
Timing is everything - wind on Saturdays please!
Has thanked: 24 times
if any of you with the slingshot setup want an H2 wing, I've got one for sale. Asking $200. As new, 2017 model I believe.
This is the stock wing on the windsurf setup and is awesome with a great range and early lift. I use it from 4.7 up to 5.8. I just got a new one, though. $200 sounds fair.
No longer selling an h2 wing (long story)...selling an NF2, which is the base hover glide kite wing. If any of you ss types want to experiment with it or use it kiting, $100.
elt
Is anybody here windfoiling with the Infinity 84cm? If so, what are your thoughts and how does it compare to other foils you've windfoiled?
Has thanked: 11 times
elt
grantmac wrote:I'm not, however a bunch of guys bought them down in Seattle. The overall impression is far better than the H2 wing (which I do have). Earlier take off but the same or higher top end. Better pitch stability and more secure in the carve.
Thanks Grant. It's weird how there's so little out there about it in terms of windfoiling. I've read it carries well through lulls which is perfect for where I live, my goal though is to have something that gets me up on foiler at a lower speed than the H2 and I know it will, I just don't know how big the difference is.
elt
grantmac wrote:Whyatt (slingshot sponsored rider) has said he far prefers the Infinity wings for overall riding and carving but he jumps using one of the fast kite wings. Basically he doesn't have a use for the H2 and honestly I consider it a crappy design. They picked a far more efficient airfoil for the infinity which is why it gains at both ends.
I've been pleased with my H2 as it's been fine in high winds where I was lit on a 3.7, but I don't have much basis for comparison. It's my understanding the Infinity 76cm makes the H2 redundant with gains on either end. I figure that between my h5 and an 84cm Infinity, I'd probably no longer need an H2.
