Windsurf Foiling Discussion
- Keen
- Contributor
- Been thanked: 3 times
- tempy
Wow!
Wow!
- tweezer
- Has thanked: 26 times
- Been thanked: 28 times
I joined the Flog Life
Cheers
Mark
Cheers
Mark
- tempy
- Has thanked: 21 times
- Been thanked: 4 times
Thanks Grant. It's weird how there's so little out there about it in terms of windfoiling. I've read it carries well through lulls which is perfect for where I live, my goal though is to have something that gets me up on foiler at a lower speed than the H2 and I know it will, I just don't know how big the difference is.grantmac wrote:I'm not, however a bunch of guys bought them down in Seattle. The overall impression is far better than the H2 wing (which I do have). Earlier take off but the same or higher top end. Better pitch stability and more secure in the carve.
I've been pleased with my H2 as it's been fine in high winds where I was lit on a 3.7, but I don't have much basis for comparison. It's my understanding the Infinity 76cm makes the H2 redundant with gains on either end. I figure that between my h5 and an 84cm Infinity, I'd probably no longer need an H2.grantmac wrote:Whyatt (slingshot sponsored rider) has said he far prefers the Infinity wings for overall riding and carving but he jumps using one of the fast kite wings. Basically he doesn't have a use for the H2 and honestly I consider it a crappy design. They picked a far more efficient airfoil for the infinity which is why it gains at both ends.
