New Foiler needs advice
Winger
Post by Winger »
My chiropractor has a place on cowichan lake and would like to take up foiling.
Any advice on foil size, where to buy, board type & size. Any used starter gear??
Thanks in advance!
Winger
Post by tempy »
Can’t go wrong with the slingshot system - relatively inexpensive and used stuff around.
Has thanked: 12 times
Been thanked: 26 times
Re: New Foiler needs advice
Post by UnusuallyLargeRobin »
Winger wrote:My chiropractor has a place on cowichan lake and would like to take up foiling.
Thanks in advance!
Need to know: intended sport (wind/wing/kite foiling, dock starting, wake foiling etc), experience, weight
Post by smartang »
A doctor with a house on the lake. Lift Efoil 200 on 5'6" efoil board. Contact
https://zensports.ca/
smartang wrote:A doctor with a house on the lake. Lift Efoil 200 on 5'6" efoil board. Contact
Yep Smartang, that's probably the correct answer! 😄
superdave
Post by superdave »
Selling my Naish Hover 135 L foil sup. 7'6" by 28.5". Track style foil box. No fins/slots. No windsurf track. SUP foil and wing only. $1200.
