Windsurf Foiling Discussion
- Has thanked: 27 times
- Been thanked: 16 times
- Has thanked: 28 times
I think for light wind foiling anything smaller than a 1500 is going to be challenging, almost frustrating, that's what I found anyways. I have the Sabfoil 1100 ( 2100 sqcm ) and the 790 ( 1550 sqcm ). You can take it for a test drive if you want. I have the aluminium 95cm mast and 900cm fuse, which is great for wind foiling that I don't use anymore.firstonlastoff wrote: ↑Wed Apr 06, 2022 1:04 pm Looking more right now at opening up the low end which for me means 10+ knots ish that English Bay gets reasonably often each month.
Hello All,
Looking for just board and foil or also sails etc? What do you weigh?otisdadog wrote: ↑Tue Apr 12, 2022 10:26 am Hello All,
Just looking for board and foil, I weigh 185lbs.grantmac wrote: ↑Tue Apr 12, 2022 1:23 pmLooking for just board and foil or also sails etc? What do you weigh?otisdadog wrote: ↑Tue Apr 12, 2022 10:26 am Hello All,
Hey FOLO!
OR
Moses/Sabfoil 790
Pros:
-a bit less expensive
Cons:
-a bit of an older design
See you out there!
OR
Moses/Sabfoil 790
Pros:
Cons:
See you out there!
firstonlastoff wrote: ↑Wed Apr 06, 2022 1:04 pm seeking comment on any or all of the following;
- tempy
- tempy
