Wing Gloves - Winter
- slake
- Has thanked: 10 times
- Has thanked: 12 times
- Been thanked: 26 times
Re: Wing Gloves - Winter
- Been thanked: 17 times
ps. I do secretly wish I could Wing. Maybe, one day.
- Highrocker
- Been thanked: 24 times
The following applies:
Warm wingfoil wishes.
velcro elastic cinch straps
- TunaCan
- Has thanked: 2 times
- slake
- slake
Annnnnd looks like vissla stopped making the 1.5mm. Lame. It was (is) honestly the most durable thin wetsuit glove i’ve ever owned and it only has one repair after a full year on the water, and that’s from scuffing my knuckles on some barnacle…
- slake
- slake
