Help Sooke basin guy looking for 130 ish board
Re: Help Sooke basin guy looking for 130 ish board
pm sent.
Yeah the Hypersonic isn't an easy board by any stretch of the imagination
- Has thanked: 24 times
Sooke Basin is challenging to sail on a fin board, something like a hypersonic and a big sail will maximize the amount of planing/working upwind you can do. If you are having a lot of spectacular catapaults, have you got enough downhaul? Having a loose leech and sail twist will definitely reduce the sudden overpowering in a gust.
And of course a foil will use a much smaller sail so you aren't as easily overpowered, while being able to sail fast at higher angles so not as concerned about staying upwind. You know you want one
