Cadboro Bay?
Cadboro Bay?
A friend said they saw a bunch of windsurfers sail at Cadboro Bay the last south easter when it was almost dead onshore and high tide. Where does one launch at Cadboro Bay? Regardless where are Victoria windsurfers going to sail tomorrow? Thanks! Rhonda
- Has thanked: 36 times
- Been thanked: 40 times
Re: Cadboro Bay?
I'm not sure about Caddy Bay, but people might be out at Willows Beach today. Just be aware of the many dangers: high tide with logs, high wind and cold water, dog poo, etc
Also, there was a poor water quality from 2 days ago in Cadboro Bay: https://bigwavedave.ca/water-quality.html?site=475#data
Other than all that it should be good
Re: Cadboro Bay?
Thanks! It looks like a day to pass regardless... it is pretty onshore. When things eventually get better at Cadboro Bay, where do people launch?
Also people launch at Cattle Point. What wind direction do people go out on those two boat launches? Cheers.
- Been thanked: 17 times
Re: Cadboro Bay?
I have launched from the main beach in Caddy Bay many years ago. As for the Cattle Point boat launches, I prefer the 1st launch (facing South) on a SouthWesterly as it's flat water and sheltered and worst case you can swim into the 2nd boat launch around the corner. I like the 2nd boat launch (facing East) on North/North Easterlies (usually fall/winter/spring) high pressure weather events which are usually coolish in temperatures. Again these are some of my favourite flatwater sessions, sometimes a bit gusty but usually pretty darn good and worst case scenario is you swim around the corner to the 1st boat launch. Even better there are usually many boaters out off Cattle Point (known as CP sometimes) in the very worst case scenario. Do remember the tide goes through this area pretty quick if you get out a ways, if you're not planing or foiling it'll take you where it wants.
Re: Cadboro Bay?
Forget Caddy Bay, even for my catamaran it was a bitch. Willows is safe, as Bobson points out the Cattle NE launch is scary for currents, the other is super gusty on W SW but can be done
Your safest SE launch is Willows but likely NOT tomorrow with logs & high tides.
Re: Cadboro Bay?
I've sailed out of the main beach on foil on a westerly a few years ago. Was pretty good, slogged in lulls and a couple of foils to get outside in clean wind (easier Cattle Pt launch). THere are a couple of accomplished wingers launch at RVYC docks (they are members) regularly and sail in the bay. It can be epic in a big SE, but the shorebreak goes about 150 m out, wouldn't even think of it on a bombogenesis day.......
Re: Cadboro Bay?
Good to know. When there is no bacteria there, it sounds like a good option. Thanks!
Re: Cadboro Bay?
I windsurfed cadboro last Saturday and was shocked to find the wind was significantly more than willows or cattle.. 20 gusting 25 with some nice rolling swell coming in ..willows felt like maybe 10 knt… I launched off telegraph bay rd /Tudor.…there’s a bench and a patch of grass just big enough to rig your sail and no rolling logs I would not normally windsurf here but worked for me that day SE wind was good .
