Board Building
Board Building
Hi all
just thought i would post some pictures of boards im building.
I have met a couple guys now who have either built or want to build.
So i thought i would post for input.
First board build .. lite wind
cedar core
epoxy/flox rails.
any comments are appreciated.
more to follow once i turn it over and machine shape.
cedar core
epoxy/flox rails.
- 8.JPG (67.68 KiB) Viewed 1792 times
- 6.JPG (55.45 KiB) Viewed 1792 times
- 4.JPG (67.81 KiB) Viewed 1792 times
- 3.JPG (58.63 KiB) Viewed 1792 times
- GregK
When you're ready to get fins for your boards, best value are from fins4sale.com ( http://fins4sale.com/index.php?cPath=2& ... bb970bcaee ) but get the 2-hole $10 ones, the $5 injection-molded plastic ones I'm told are poor. The $10 ones aren't bad, I got some of the 1.25" and 1.75" and the shapes are decent, and the material's solid. Only downside is the gloss finish, as I'm told a gloss finish is the worst for keeping water flow attached to the fin. But nothing a quick high-grit wet-sanding won't fix.
couple new shots.
boards on the vacuum table at this stage almost done
- 13.JPG (67.31 KiB) Viewed 1626 times
- 9.JPG (51.83 KiB) Viewed 1626 times
A picture For JL in thanks for the link.
Again thanks for the link to the guys post on building a Hollow Mako.
Its a fun project so far
- bottom done just flipped it
- 28.JPG (62.02 KiB) Viewed 1639 times
- frame done
- 20.JPG (60.44 KiB) Viewed 1639 times
