Board Repair
Hey Bobson
BArricuda surf boards.
and you may want to try this stuff called marine FX.
at industrial plastics
Re: Hey Bobson
Correct me if I am wrong, but I think he means Marine-Tex. If so, its a good easy to work with epoxy that fixes anything, its what I used to fix a big long valley indentation on the bottom of my board. I did it ugly, but hey its smooth enough!AC wrote:and you may want to try this stuff called marine FX.
-post a photo Bobson!
After taking your old Futura to a shop to have them repair it, I did another board a lot worse and did the repair myself. As Kus lectured me a while back, just get the thing sealed back up and get back out there. While I didn't take his advice entirely, the fiberglassing was pretty easy and my finished product is as good as the repair shop.
There is ample experience with board repair on this site and the other resources on the web are great (board lady etc.) Downwind Dave even has a McGyver vacuum pump that can be used for water removal or for laminating layers of PVC foam for those deeper repairs. Works like a charm.
Marinetex is okay for little stuff but it can add weight if the wound is nasty. With some proper filler, epoxy and glass it is pretty easy to make a light and durable repair.
- Has thanked: 27 times
- Been thanked: 16 times
board repair
So what exactly are you fella's saying...???
Bobson: "does this harness make my A$$ look fat..??"
Nanmoodude: "No your A$$ is fat all by itself"
Saulmanson: "Good one Nanmoo"
I didn't hear anyone say 'No Offense..."
sailing
Nope, I'm saying I'm number 1. Figure it OUT!
Actuallly, I was kinda bored cruising up and down the lake, pretty much anywhere I wanted so I was pointing up to look at the beautiful sky. Just enjoying my surroundings Jimmy!
board repair
Yes, this is my daughter......and thank you....None Taken!
http://www.bigwavedave.ca/gallery/displ ... m=43&pos=0
