Screwed
Screwed
I have a fin - a select model and am looking for the screw for it - mine is 4 inches long or so and need a longer one as does not fit!!
Any leads are appreciated
Generally single screw power boxes are metric, the dual screw powerboxes can be SAE or Metric. Perhaps this is a deep tuttle box and you are fitting a regular tuttle? One or two screws....one it's a powerbox, metric and the screw should not be that long unless you have some wacky homemade board.
Capital Iron, Trotac marine (get ready for the price hit), Can Tire maybe....for longer length best bet probably get a washer and hex head bolt from Home depot and cut a slot into it with a hacksaw
- SmallWaveSteve
I've had the pleasure of looking for metric stainless screws for paintball guns on many occasions. I've had the best luck at Home Depot followed by Home Hardware (at least the sidney one), unless you go to Fastner Force, but they're more a commercial place and are prettymuch only open bank hours.
Last edited by SmallWaveSteve on Thu May 16, 2013 9:31 am, edited 1 time in total.
finding the preferred head is the issue, tough to find phillips or torx heads in that length....therefore cutting a single slot in the top of a hex head with a hacksaw or a narrow cutting disc with a dremel works pretty good...protect those eyes
Screwed - no longer
Thanks for the replies and help
Ol Capital Iron was the ticket!
Perfect
thanks again
Perfect
thanks again
