iKamper Roof Top Tents
What's up Nitinat faithful?!
Many of you will recall that I had 3 seasons at the lake with an ARB Simpson III roof top tent. You'll likely also have seen a number of other similar models up at the lake.
If you're considering a roof top tent for this coming season, hit me up! I've done the research and have decided I want a hard shell. Of the options, the iKamper models are the only ones that fold out into a much larger tent.
The Skycamp by iKamper is the size of a king size bed and is only 150lbs. They intend to retail the tent at $4000 CAD but are also about to do a pre-sale Feb 27th on Kickstarter at $1950 USD.
I reached out to them and they agreed to sell me 10 of them for $100 less per tent or $1850+$200 shipping = $2050 or about $2700 CAD each.
If I can get 9 other people together we all stand to save. Hit me up, need to order in +/- 1 week or so if this is to happen.
JZ
Specs:
Gross Weight - 150 lbs (68kg)*
Weight Limit - 900 lbs (400kg)*
Speed Limit - 75 mph (120kmh)*
Mattress - 75"x 82"x 1.2" (3cm)
Sleeping Capacity - 2 Adults and 2 Children
Ladder - Telescopic Aluminum Ladder
Material:
Top: Fiberglass
Floor: Aluminum Honeycomb
Fabric: Poly 250D / Poly Cotton
Mattress: High Density Memory Foam
Website: http://www.ikamper.com/
JZ
Specs:
Material:
Top: Fiberglass
- dim2.jpg (17.73 KiB) Viewed 1082 times
- dim1.jpg (22.31 KiB) Viewed 1082 times
- truck3.jpg (157.68 KiB) Viewed 1082 times
- truck2.jpg (543.74 KiB) Viewed 1082 times
- truck.jpg (289.8 KiB) Viewed 1082 times
