Windsurf Foiling Discussion
Bobson
Been thanked: 16 times
Post by Bobson »
Post by smartang »
Has thanked: 28 times
Post by Tsawwassen »
firstonlastoff wrote: Wed Apr 06, 2022 1:04 pm Looking more right now at opening up the low end which for me means 10+ knots ish that English Bay gets reasonably often each month.
I think for light wind foiling anything smaller than a 1500 is going to be challenging, almost frustrating, that's what I found anyways. I have the Sabfoil 1100 ( 2100 sqcm ) and the 790 ( 1550 sqcm ). You can take it for a test drive if you want. I have the aluminium 95cm mast and 900cm fuse, which is great for wind foiling that I don't use anymore.
otisdadog
Post by otisdadog »
Hello All,
otisdadog wrote: Tue Apr 12, 2022 10:26 am Hello All,
Looking for just board and foil or also sails etc? What do you weigh?
otisdadog
Post by otisdadog »
grantmac wrote: Tue Apr 12, 2022 1:23 pm
Just looking for board and foil, I weigh 185lbs.
BigD
Post by BigD »
Hey FOLO!
OR
Moses/Sabfoil 790
Pros:
-a bit less expensive
Cons:
-a bit of an older design
See you out there!
firstonlastoff wrote: Wed Apr 06, 2022 1:04 pm seeking comment on any or all of the following;
Post by tempy »
I have an H2 kicking around if you want to have it Tempy.
Post by tempy »
