BWD mobile site
- Has thanked: 36 times
- Been thanked: 40 times
BWD mobile site
The BWD website is now much better to use on a mobile device:
http://bigwavedave.ca/mobile/bwdmobile.html
Huge thanks to Keen for his many hours of work on this. It's only been tested on a few devices, mostly iOS- iPhone, iPad, iPod Touch and one Android (thanks to TheLaw). So if you have any problems please post here with an explanation. Comments and suggestions are also welcome.
If you add it to the home screen from Safari on an iOS device it should run like an app
Just need a catchy phrase now like:
"Know before you go, but if you've already gone then you can still find out"
"Now you can put BWD in your pants and take it with you"
... or something like that
- Keen
- Contributor
- Been thanked: 3 times
hopefully it's reasonably intuitive but if not here are a few tips:
- touching/clicking the home page banner takes you to the main bwd site
- in the latest reports tab, touching/clicking a row will bring up the 24 hr wind plot
- in the imagery tab, when you're using a small device it will shrink the image. if you touch/click the image once it should show it full size and then you can pan around. touching the image again should restore the shrunken size.
- the underlying technology uses fairly modern browser standards so if you have an old device it might not work... sorry.
- if you use it on a non-touch device you need to simulate scrolling like you're touching the screen. (click, hold down, drag, release)
- Keen
- Contributor
JL: if you can screenshot your page it might help me to fix it. The application automatically 'themes' based on your device so it looks quite different on Apple iOS (which I use).
MikeH: I don't have access to a BB device to check it out. Is your operating system up to date? Which device are you using? There are BB simulators available so I might be able to reproduce the issue. You can PM me details if you like.
Also, if there is a way to enable a javascript console in your browser so you can tell me the error I might be able to address it.
Thanks keen . I will work on that. http://www.bigwavedave.ca/gallery/album ... re0007.jpg You can see the problem I hope. Thanks
- Russian Dood
Code sharing for Android
Hi guys
I was thinking about code sharing for Android (ICS).
- refresh icons so they would show the content of the app.
- refresh icons so they would show the apparent window in the content
- refresh icons and stuff so we can arrange from ICS
the example - you are coming on the page and instead of looking at "bubbly rubly" speed bump page you are looking at something designed by the designer. The input method would be like 15 min, but the output will be great.
And if you don't want to do that - that's cool as well.
Cancer must die!
It seems to be working now on a bb bold 9900. The device was in fact updated. All I did was delete the cache, cookies and a few useless apps and language supports - whether or not that helped, nobody will know because I didnt check to see if it worked just prior. BWD Mobile looks Fabulous Keen! Noice workMikeH: I don't have access to a BB device to check it out. Is your operating system up to date? Which device are you using? There are BB simulators available so I might be able to reproduce the issue. You can PM me details if you like.
