FWD Loop motivation
Every joint I had ever reviewed showed this type of report seems like "early degen change" is like the date stamp on these reports. The tear, and most of us have quite a few of these, will just cause lots of scar tissue making it much stronger albeit a bit troublesome with range of motion, certainly no excuse to push the buddies ahead in line there, MTM Besides, I think sailing in a straight line is harder on your shoulder than loopingmortontoemike wrote:"Review of imaging shows some early degenerative change of the right AC joint. As well, there is appears to be a small osteophyte at the footprint of the rotator cuff with some cystic changes in the region. There is some sclerosis over the lateral aspect of the acromion as well. Review of the ultrasound report confirms a full thickness tear of the supraspinatus measuring 1 cm by 1.9 cm." (The tear is permanent.)
probably means that the bottom of my board will forever be pointed towards the water.
And yes, Wdoc, I know when to sheet in.....it's the purposely steering off the road into the tree syndrome maybe closing my eyes will help
- mortontoemike
KUS wrote:Perhaps you should say, a completed loop KUS. It's not the looping that causes the pain. It's the crashing ...mortontoemike wrote:"Review of imaging shows some early degenerative change of the right AC joint. As well, there is appears to be a small osteophyte at the footprint of the rotator cuff with some cystic changes in the region. There is some sclerosis over the lateral aspect of the acromion as well. Review of the ultrasound report confirms a full thickness tear of the supraspinatus measuring 1 cm by 1.9 cm." (The tear is permanent.)
I wish my TOW was longer!
Mike.....you forgot to add the bottom half of the report:mortontoemike wrote:"Review of imaging shows some early degenerative change of the right AC joint. As well, there is appears to be a small osteophyte at the footprint of the rotator cuff with some cystic changes in the region. There is some sclerosis over the lateral aspect of the acromion as well. Review of the ultrasound report confirms a full thickness tear of the supraspinatus measuring 1 cm by 1.9 cm." (The tear is permanent.)
Can't wait to see all you guys looping overhead this summer though. And KC777 and FOLO too!
"and upon even further review of imaging we see that the same patient's liver seems to be red tinged, likely caused by repeated rinsings with 750ml of a toxic (yet tasty) reddish liquid."
K
- mortontoemike
K
Good for the stomach. http://multiculturalcookingnetwork.word ... e-stomach/
Good for the heart. http://planetgreen.discovery.com/food-h ... heart.html
Good for long life. http://www.metro.co.uk/lifestyle/897879 ... e-know-why
Good for sex. http://www.yourtango.com/200929845/red- ... dy-implies
For all we know it will help us to forward loop!!! Looking forward to the summer KC. See you on the water.
And thanks for the original video post WindDoc.
personally i always unhook, but i learned back in an era of very short lines. You can loop just fine staying hooked in (that is how you toss a 1-hander), i think it would be one way to stay seriously committed! Landing unhooked will give you more freedom to get waterstarted if you land less than perfectly.
- Been thanked: 19 times
IMHO Staying hooked in is a drawback to learning good form. It's something you can do AFTER you've learned the rig "throw" properly. Because you need to extend the front arm fully in front of you as well as to windward, staying hooked in will limit the range of motion. Plus, the sail needs to be sheeted out on take off a bit and if your lines are too short, they'll prevent this movement too. There's no reason to stay hooked in unless you want to throw a shaka back at the beach to your buddies with the front hand . Besides, landing an over rotated forward loop hooked in will lead to bad things.
I had a look at the video again. He's definitely unhooked.
Liver
OK it's all clear now, it's the flat landings on your back that does
in the liver, not the wine. Thanks MTM
- mortontoemike
Hey. Joostio. Here's someone who does a forward loop AND carries a purse!
http://www.continentseven.de/windsurfmove148.html
Not at the same time .... but still ...
- Joostio
- Has thanked: 2 times
A question for those who can loop. Can you loop on both tacks? Just as comfortable on both? I am comfortable jumping on both tacks even though I ride surf and snow boards regular as opposed to goofy. On skis or the board I only 360 in 1 direction, I rotate clockwise, therefore I suspect I will prefer looping on port tack. Any of this make sense loopers?
we tend to have mostly starboard ramps around here so that's the strong side for most. If you sail around looking for a good ramp on port you will get less chances and wont learn as fast. I learned down in ventana on port, so i feel ok on both tacks. at nitinat, the ramps can come from either way though so you have to be ready!
Re looping on both tacks, you'll definitely have a favoured tack but fight the good fight and get them going on both tacks. For me I was always a better starboard jumper but looping came more easily on port because a) I was already doing sketchy off-balanced nose first landings on port so I didnt have to unlearn alot of firmly entrenched muscle memory on that tack and b) right / dominant hand is back hand on port which makes yanking on the boom easier.
My advice for learning depends on age and where you are sailing. If you are young and sailing in a place with big wind and jumps ie Gorge then go with the 'sheet in and hold on' approach. You'll do endos and break a bunch of boards in the process but will look like badass. If you are not in that category then follow the Remko / Jem Hall / Wymeroo method. My $0.02.
