Need new pump
man, they are available anywhere pretty much....support Canadian-owned stores and outlets try yer local hardware store first even if it means an extra $2, the invisible costs are tremendous and already noticable sorry, I guess I'm a hypocrite sometimes but I'm taking a stand in support of local stores which are being rubbed out in favor of Wallyworld and other boxes
This is the exact same pump with the exact same mold marks and writing. My guess is that they come out of the exact same factory. There handles break in the exact same place.Penguin wrote:Walmart, $11.99. They are yellow and look to be the same as a $24.99 pump from Capital Iorn.
I agree, supporing local/Canadian is worth a premium, but 100%-- I don't have an unlimited budget.
any of the pumps that are supplied with the kites or the same ones you buy at CT or Wlamart work just fine. I've never broken on in over 6 years of kiting: the key is to use two hands and keep it lubed. Remeber I'm still talking about your kite pump here!
If you use one hand, you can't grab one side of the handle, your hand must grab the middle of the handle above the shaft without covering the air intake.
A good thing to do if you can't remeber to lube your pump at home is to wipe the oil off your dipstick from your vehicle a few times and use that to lube the seals inside the pump. It's also a good idea to wipe the pump out first.
