Wing Gloves - Winter
- slake
- Has thanked: 10 times
- Has thanked: 14 times
- Been thanked: 27 times
Re: Wing Gloves - Winter
- Has thanked: 27 times
- Been thanked: 16 times
ps. I do secretly wish I could Wing. Maybe, one day.
- Highrocker
- Has thanked: 13 times
- Been thanked: 26 times
The following applies:
Warm wingfoil wishes.
velcro elastic cinch straps
https://www.amazon.ca/gp/product/B097BG ... UTF8&psc=1
https://www.amazon.ca/gp/product/B0964D ... UTF8&psc=1
- TunaCan
- Has thanked: 2 times
- Been thanked: 3 times
- slake
- slake
Annnnnd looks like vissla stopped making the 1.5mm. Lame. It was (is) honestly the most durable thin wetsuit glove i’ve ever owned and it only has one repair after a full year on the water, and that’s from scuffing my knuckles on some barnacle…
- slake
- slake
