My front lines are way more stretched out than the back lines. Is it ok to switch them? Are all the lines the same strength in OR line sets? I can't tune the bar correctly to equalize the front and back lines anymore. Thanks.
By "oversheeted" I guess you mean overly sheeted out with the longer lines now on the rear. I thought "sheeting" had to be qualified with "in" or "out" since it can of course refer to both ?
No problem switching the lines around just make sure you rememeber that the 'tags' indicating front (f) and back (b) are now reversed. OR makes two different sets of lines with different strength ratings. The higher strength ones stretch a bit but not as much as the others.
I find front lines about 1-2 cm. shorter than rears works for me. Don't forget you can adjust your lines @ the kite as well as the 'pigtails' @ the chicken loop !!! Just ensure that each pair of lines are matched..You know tie em to line secured to something solid and tension to ensure they are parallel...
