Website loading problems
Has thanked: 36 times
Been thanked: 40 times
Post by bwd »
Kite Kook: Has anyone else had occasional difficulty loading this site over the last few days? It just seems to hang without loading for me, yet no problems loading all other sites... - Monday June 15, 5:15PM
Jl: I have ... Telus ? - Monday June 15, 5:18PM
Mortontoemike: Shaw too. - Monday June 15, 5:27PM
Kus: me too, both Shaw & Telus, mostly homepage, I think it's Islandnet's server - Monday June 15, 8:41PM
There are a few things that could cause this. The bigwavedave.ca domain name is hosted by easydns.com and the actual website is hosted, in part, by islandnet.com. When things like this happen they tend to just blame each other. It is also very difficult to diagnose since it doesn't last very long.
So the next time it happens, please try a trace route and note the date/time and post here:
If you are using XP, go to the Start menu > Run > then type
<b>tracert bigwavedave.ca</b>
copy and paste the results here.
Post by bwd »
It's seems to be still happening...let me know? thanks
loading
Post by GWIND »
I'm on Mac on shaw and having trouble, unless I load a web cam address first then go to home page. Home page must be issue.
MartyD
Post by MartyD »
I have the same home page issue. If I load a cam first im fine.
Post by JL »
I find the trace clears without me being able to copy it Dave ? :shock: I find that BWD boots up if I switch browsers ( IE - F-fox )
jellyfish
Unable to load homepage
Post by jellyfish »
I've been experiencing the same problem recently. Unable to load the homepage unless I open a webcam. Fine this morning and now but unable to access the site around 4pm today. I have had the same problem a number of times in the past. Switched to Shaw this month after years of Telus torment. Thanks Dave for the service you provide to the rest of us ....it is hugely appreciated 8)
Post by bwd »
Thanks everyone. Sorry, it's a very annoying problem. I'm guessing it's an islandnet problem with how PHP pages are being handled. The problem is that all other islandnet pages I visit are fine. I will talk to support again in the morning.
When it happens next can you check these two pages:
1. http://www.bigwavedave.ca/images.htm => loads yes/no?
2. http://www.bigwavedave.ca/latest.php => loads yes/no?
I suspect 1 loads okay but 2 doesn't?
For the trace route: right click > select all > then hit enter. But you only need to post it if the trace does not end up at cluster.islandnet.com
Post by JL »
I'm on it ... Winds up !!! :?
~~~~~4j~~
Post by ~~~~~4j~~ »
It happened again late last night.
This is exactly what happens to me: 1 loads, 2 doesn't. I tried the trace, but I too had trouble with it disappearing when it finishes. I tried Alt+PrtScreen and caught this when it was about 3/4 done.
BWD Trace.jpg (39.18 KiB) Viewed 6607 times
tried for quite a while yesterday, usually hitting reload repeatedly ends up finally loading the page or exiting firefox and then restarting works for me.
Yes, cams came up, no go on the forecast page OR the forum page, no go for over an hour. Gave up.
Good way to ease off the website, cutting back on the addiction :roll:
Post by bwd »
Islandnet did some php upgrades today to try and fix the problem. Let me know if you have any more connection issues.
dave
Post by JL »
'php' hanging again ... BWD only available 'htm' ... For a while 8)
for quite a while already, all pages for me and then all of a sudden they are all like lightning....then die again. :evil:
Post by bwd »
I sent a message to Islandnet support at 7am this morning when I noticed it was still happening. They have made some changes so let me know if there are still problems.
