Does Anyone know anything about this gear?? Wondering what f
Tyvealive
Post by Tyvealive »
Trying to find out what find would fit this board. It's an old original
"Sailboard" think it'd be fun for paddling around on. The guy I got it from didn't know anything about the fins.
Does anyone have experience with these, or know what I can use on it???
Chere's, Ty
Tyvealive
More photos
Post by Tyvealive »
Sailboard. .
That one takes the Top Fin System. :lol:
did you try a us box fin? maybe with some epoxy putty.
Has thanked: 12 times
Been thanked: 26 times
Post by UnusuallyLargeRobin »
Sailboards all used standard US fin box from what I remember (owned a couple). That box looks odd in that it doesn't seem to have the screw plate entry slot, but looks like the box has the slot for a plate. Try a standard fin, you'll probably have to wiggle the plate into position in the slot.
yep standard fin A box should fit, you can also replace the box if needed with an alu Chinook box. I guess you probably just cannot see the slot at the rear due to picture being cut off, the old ones did not have a middle slot for the washer, just a tail end one.
There are a few old fins like this kicking around I am sure. If the plastic box fails Gorilla glue it and its parts into place, should work ok. Usually the screws holding the box in are stripped and/or leak and the box can crack altogether, for paddling should be fine enough. 8)
Finding another mast base for it should be tricky but mounting a Chinook base is possible to sail it too.
Holy
Post by GWIND »
I'd use a chain saw on it 😁
